View Single Post
Old 05-24-2008, 06:06 PM   #114
blindfold
Trader Rating: (14)
Default Recaros
Evo Recaros are in, I heard it was the new thing to do
But seriously, these are one of the BEST mod you can do for a better feeling of the car. To me peripheral and driver input items are extremely important and this is better than the TiC's sueprshifter set, which replaces the all the bushings related to the shifter, linkage etc, better than the thicker wheel from the 05. Somehow you actually sit in the seat instead of on or on top of the seat like the OEM unit, so far I love it, perhaps a more detailed review in due time.
Surprisingly, it was more difficult to take pictures of the seats after they are installed, am I the smart one here are some quick shots:
Last but not least, big thanks goes to member Peleg for his help. Follow his advice, solder about 1 inch of extra wires onto the 3.3ohm resistor so you can easily into the sensor, my advice is shrink wrap all exposed areas and use single strand wires. I used copper wires that are braided together with smaller diameter, simply solder the ends and you should be good to go. Also use the Folox detergent recommended by Peleg, they work pretty well on the Recaros. Enjoy and highly recommend this mod.
